9 members (GIJOE298, Biermann, Phak1, DadsFirstPickup, diseasel, Shade Baby, 46 Texaco, Woodcmiami, 1 invisible),
104
3
Mod | | | Forums66 Topics128,154 Posts1,056,835 Members48,456 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2004 Posts: 29,850 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,850 | You're WAAAAAYYYY too tight. Torquing a bolt against a part that's able to compress is a lost cause, no matter what the manual says.
You can replace the gaskets now, or wait until they leak. When you do, tighten the bolt just enough to remove any slack, then tighten approximately 1/4 turn further. Wait a few hours and recheck the bolts. If any of them turn freely, go about another 1/8 turn tighter. This procedure has worked for me for a little over 50 years, with very few leaks or distorted gaskets and/or sheeet metal. Jerry
