0 members (),
139
7
Mod | | | Forums66 Topics128,077 Posts1,056,033 Members48,433 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | fleetsides have rollpans?? have you pondered the shape of a panel truck tail behind the bumper? know there's a rubber seal between that tail and the bumper? thought why that's as it is? thought how much work it'd be to repair that lower door sill if someone bumped you without a bumper?
if you were set on having the tail that way, you'd be looking at fabricating your own ... hopefully you'll have very good fitting rear doors with the correct weatherstrips
Bill | | |
