| Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,796 | Did you push the clutch in when you stopped? Try getting it running about 30 MPH, push the clutch pedal in, and nail the brakes hard, repeatedly. Sometimes it takes a big jolt to break the disc loose from the flywheel if it's rusted tight. Jerry
