1 members (DES57),
119
3
Mod | | | Forums66 Topics128,193 Posts1,057,257 Members48,466 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: May 2005 Posts: 8,983 Sir Searchalot | | Sir Searchalot Joined: May 2005 Posts: 8,983 | No power to one side of brake switch? I agree with Tiny amd Casey. Just to repeat the obvious: trace backwards from switch, using Tiny's schematic, to find where hot first appears. You just need a circuit tester. (sharp tipped prong with a bulb and clip sold in many stores) you probably have one. Quickest way: Run a fused/unfused test wire from battery to switch and depress brakes. That will make you feel good and confirm that it's just lack of juice.
Right is right, even if everyone is against it, and wrong is wrong, even if everyone is for it. - William Penn | | |
