0 members (),
135
0
Mod | | | Forums66 Topics128,110 Posts1,056,241 Members48,437 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2005 Posts: 1,636 'Bolter | | 'Bolter Joined: Mar 2005 Posts: 1,636 | I believe it is a CCP set up. I looked through the pictures on the link you gave and it looks like he was able to use the original hole for the pedal.
If it were moved inward (towards the drive shaft) about 3/4 inch then the lever would be right.
May have to make a spacer plate to go between the master cylinder bracket and the frame bracket. | | |
