| | | Forums66 Topics128,288 Posts1,058,577 Members48,492 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2002 Posts: 9,117 'Bolter | | 'Bolter Joined: Mar 2002 Posts: 9,117 | You shouldn't count on curing the oil leaks with a PCV system. It is better for the engine and it will help keep blowby fumes contained. You would set it up the same way you would fro a 235. I have mine drawing from the converted vent tube and the air inlet is a filtered oil cap. | | |
