I have several trucks with the acc position. I believe spare parts is correct on turning it that way with the paper clip in. If you can turn it you may be able to remove it with that trick. If not remove the door lock cylinder and take it in to the lock smith and have a key cut for it and hopefully it hasnt been changed and is the same as the ignition.
65 K10 Longbox Fleetside Big Back Window Custom Cab
65 K10 Flatbed
Old School Parts 60-66
(208)946-6173
[email protected]
