The clutch is actually bolted to the flywheel,,,,the clutch disc however is not. Can you push the pedal to the floor and roll the truck? How was the fluid level??
There is enough good in the worst of us and enough bad in the best of us that it does not behoove any of us to criticize the rest of us. - - Be yourself. If you are ever lost, It will be much easier to find yourself if you know who you are!
