| | | Forums66 Topics128,035 Posts1,055,564 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#84534 10/21/2007 4:53 PM | Joined: Aug 2007 Posts: 156 Shop Shark | | Shop Shark Joined: Aug 2007 Posts: 156 | I have to replace the seal on the ball collar for the front u joint. During degreasing and disassembly I found a grease fitting on top of the u joint housing on the transmission. What type of lubricant should I use, and how would I know when I've pumped in sufficient lubricant since it is a sealed assembly? I have the bushing style of front u joint. | | |
