Ok, bearing is fine, and not tight. I loosened it and it did not change the tightness. So I loosened the bleed screw, and out came fluid. About a table spoon amount. I tightened back up on the screw, and the disk is now free. Any help??
BY the way, I have a mustang duel master cyylinder for a drum/disc setup which is recommended by many others who have done it in the past.
