| | | Forums66 Topics128,048 Posts1,055,663 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2012 Posts: 35 New Guy | | New Guy Joined: Apr 2012 Posts: 35 | HERE's a good write up from MARTINSR over on hotrodders.com. Most does apply to a 50's Chevy Cars, BUT it applies to adjusting most any older car/truck doors. Doors: If the doors are off the car, bolt the hinges to the door and the cowl in the middle of the movement allowed. Let’s face it, it “shouldn’t” be too far off the center of holes. If the doors are on or if after putting them on things are way out of whack, raise the door up on the hinges as far as it will go while still staying about the right height. You always want to start high, it is much easier to come down than go up. Besides this is the ONLY time you will loosen all the bolts on the door. I don’t mean ALL the bolts, leave the hinge to cowl (or center post on a four door) tight. Only loosen the door to hinge bolts. Unless it is WAY down then you may need to move the hinges up too. But do one at a time, both door to hinge or both hinge to cowl/center post.
While moving the hinges aligning the door NEVER loosen all the bolts on the hinge, NEVER. Loosen all but one, just till it is still a little looser than “snug”. Leave that last on just a little snug. Let’s say the door fits well but is a little too far rearward. NEVER loosen top and bottom hinges and move it forward. Loosen the top hinge to cowl/center post as described above and lift the rear of the door, a LITTLE. This will push the upper hinge forward. Now TIGHTEN that one bolt that was left snug. Do the same on the lower hinge, pushing down, but remember the weight of the door is helping, so little push is needed. Many times no pushing at all, just the weight of the door will do.
If the door fits well but is out at the top or the bottom, again, loosen ONE hinge to DOOR in the manner described and push it out or in. If it is out or in at the top rear for instance, move the bottom front in the opposite direction. This will pivot the door on the striker, and move the rear top where you want. Moving the bottom rear takes moving the top front of course.
You may need to twist the door. If the front fits well and rear is out at the top (or bottom, just reverse) you can put a block of wood at the rear of the door at the top lets say and push in on the bottom to twist the door. Some will take a LOT of force to bend, and be VERY careful not to let your fingers hang around the outside of the door edge!! I lost a finger nail doing this on a ’69 Shelby GT500 convertible once (remember it well) when the block of wood fell out with all my weight on the door while twisting!!
Tip: If you are hanging the door and you have access to the hinges (either through the wheel well with the skirt off or if the fender it’s self is off) you can simply hold the door up to the opening and push the latch shut. Then put the bolts in the hinge. I can often install doors all by my self in this way.
An elephant is a mouse built to government specifications.
