7 members (mason86, Phak1, klhansen, tclederman, Ponchogl, dt235sd, Hanks custodian),
70
1
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,050 Posts1,055,672 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2008 Posts: 212 'Bolter | | 'Bolter Joined: Feb 2008 Posts: 212 | I bought my turn signal from obsolete chevy and directions and wiring diagrahm came inside the box. The letters inside the circle are the terminals on the turn signal flasher. There should be two different circles showing different wiring diagrahms depending on the type flasher you have.Just study the diagrahm and use wire nuts until you get it right. When it's right them crimp or solder . I had to build my harness from scratch one wire at a time.Take your time , you can do it. | | |
