| | | Forums66 Topics128,282 Posts1,058,490 Members48,490 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#84432 10/17/2007 2:23 AM | Joined: Feb 2005 Posts: 469 Shop Shark | | Shop Shark Joined: Feb 2005 Posts: 469 | The long shaft pump started in 55 and went till 62 and to my knowledge are all the same unless their was a special application for big trucks. If you have a double pulley balancer the groove nearest the block should line up with a standard pump pulley and generator. If these do not line up you may to make sure the balancer is all the way on the crank and you have the correct pulleys for the pump and generator. | | |
