Brokenhead, yes, everything including the filler tube. The carburetor was the first thing to be replaced however. It was run several times with a new carb and old everything else, so maybe I messed up my new carb. May rebuild it and see what happens.
The carburetor has a fairly loud sucking noise, especially under load. I can even hear it very well from inside the cab, windows closed.
