| | | Forums66 Topics128,012 Posts1,055,315 Members48,419 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2001 Posts: 5,337 'Bolter | | 'Bolter Joined: Jan 2001 Posts: 5,337 | The pitman shaft has four keys on the shaft spline and would be way off of if the arm was put on wrong. However you could have installed the pitman teeth in the wrong position in the worm nut. I have also seen pitman shafts with a torsional twist that gave a similar response.
See the USA in your vintage Chevrolet! My Blog | | |
