7 members (Mike1933, mo2cyl, Barnfind49, Otto Skorzeny, Jon G, ShopRag, Rusty Heaps),
219
6
Mod | | | Forums66 Topics128,282 Posts1,058,496 Members48,490 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2010 Posts: 146 Wrench Fetcher | | Wrench Fetcher Joined: Apr 2010 Posts: 146 | So I've bolted on the new adapter bracket and dual res master cylinder. When I try to bolt the new eye bolt/push rod to the brake lever arm, it doesn't line up. Seems like the MC is 1/2" too low. Also seems like the push rod going into the MC is too long. Anyone have any problems like this? The master cylinder has a ring holding the main bore plunger in place. I assume the plunger will move deeper into the bore once I remove the ring? That would allow the new push rod to go into it more. See pic below: http://s1107.photobucket.com/albums/h394/52ChevyProject/?action=view¤t=AdapterBracket.jpg | | |
