| | | Forums66 Topics128,049 Posts1,055,691 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#8398 05/13/2005 11:03 PM | Joined: Feb 2001 Posts: 81 Shop Shark | | Shop Shark Joined: Feb 2001 Posts: 81 | The easiest thing to do is pull the driveshaft and take it to a shop that specislizes in driveshaft balancing. I had a vibration for years until I took my shaft to a good shop. Mine was bent. a rebuild and balancing fixed the problem!! Hope this helps. Just because the driveshaft is new doesn't guarantee that it is balanced. Good luck!
Green Machine
