0 members (),
54
3
Mod | | | Forums66 Topics128,072 Posts1,055,906 Members48,429 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2001 Posts: 5,337 'Bolter | | 'Bolter Joined: Jan 2001 Posts: 5,337 | The difference in short and tall intake is not car v truck. The parts book shows pass and truck using the same intake. The tall was used up through 1958, then because the hood was lowered on the car line in 1959 the shorter intake was used. As far as which flows better I doubt there is much difference although the rated HP went up in the later years. That most likely had nothing to do with the intake. Both manifolds take a difference length throttle rod.
See the USA in your vintage Chevrolet! My Blog | | |
