7 members (2-Ton, RoadsScholar, Wayne67vert, Peggy M, moparguy, ESum, 1 invisible),
70
1
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,211 Posts1,057,467 Members48,471 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2002 Posts: 2,777 Carburetion specialist | | Carburetion specialist Joined: Nov 2002 Posts: 2,777 | Some Rochester 2GC carbs use two balls, others one only. Would be easier to give an intelligent answer if the identification number of the carburetor were given.
However, since that is not present, "shotgunning" the answer:
All of the 2GC series carbs that I have personally worked on had the larger steel ball under the venturi cluster.
Those that I have worked on that have a ball under the pump use the smaller aluminum ball under the pump.
It is possible that a siphoning action could occur if the smaller aluminum ball were placed under the venturi cluster, thus artificially enrichening the mixture causing the engine to stall from an overrich mixture.
Jon.
Good carburetion is fuelish hot airThe most expensive carburetor is the wrong one you attempt to modify. If you truly believe "one size fits all," try walking a mile in your spouse's shoes!The Carburetor Shop | | |
