| | | Forums66 Topics128,103 Posts1,056,188 Members48,436 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | There is a break in the circuit from the gauge to the sender to ground. - Check continuity between the gauge and the sender. - Then, Check continuity between the sender "cap" (on the outside of the tank) to the ground (the frame, for example)
If continuity checks out, you might have a bad sender in the tank.
