I solved the misaligned beltline problem. I want to thank the ones that gave advice. Since the lower front cab corners were toast, I used some metal pipe and braced from the inside of the upper firewall to the rear of the floor by the seat riser. This pushed the cab nose foward and made the beltline line up and at the same time gave me better front and rear door gaps.
