| | | Forums66 Topics128,156 Posts1,057,021 Members48,460 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2008 Posts: 1,775 'Bolter | | 'Bolter Joined: Mar 2008 Posts: 1,775 | If your side gears are pitted, I would definately start looking for another center section. I also see that you have some concerns about your axle splines too. I think the best way to go, is a whole other axle. There's always guy out there that are getting rid of the torque tube and going to an open driveline. Shouldn't be that hard to find.
You could convert to an open driveling also. You'll need an open driveline rearend. 55 on up trucks had open drivelines. Also 4x4 1/2 ton trucks from the 80's used 6 lug axles. You'll have to get an open driveline transmission and driveshaft to fit the new axle though. | | |
