| | | Forums66 Topics128,159 Posts1,057,033 Members48,460 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2011 Posts: 12 New Guy | | New Guy Joined: Dec 2011 Posts: 12 | I have a 1953 GMC, 5 window 1/2 ton pickup that I am slowly working away at. I have removed the box and began body work on it. I have also removed the torque tube and rear end out of the truck for tear down and rebuild. One I opened the rear cover I was greeted with rusty slime and water. Any thing in the slime was ok but anything above is got some rust on it. All this from a broken vent cap. Also the 17T axle splines are almost worn right out.
So when is pitting on the gears bad enough to cause fatal damage to the differential? I have spent countless hours searching this forum with little answers to my next questions. What is the easiest way to save this rear end, either with a different 3rd member, another 53 torque tube rear end (hard to find a good one in canada), or a complete axle swap?
I would like to keep the truck as original as possible but i am open to modifications if original parts aren't available.
1953 GMC 9300, Five window 1/2ton
