| | | Forums66 Topics128,209 Posts1,057,462 Members48,471 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#83462 09/26/2007 5:28 PM | Joined: Oct 2006 Posts: 13 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 13 | I made sure that the link allowed the primaries and secondaries to close all the way. The secondaries only stay open when the engine is running, and even then it's not more than a few degrees till they close. Though I realize that can make a big difference.
Thinking back now, it had a hesitation when running on only primaries. When I would just slightly crack the secondaries by hand the idle would increase a bit and the hesitation would go away. Could this mean puddling? Too little air flow allowing fuel to condense in the intake until the throttle is opened?
When we're talking about the secondaries opening, we mean the upper, air velocity actuated, and spring calibrated auxiliary valves right? All the pictures and drawings I could find of 4GC carbs show a single link connecting the primary and secondary throttle valves.
I know my way around Edelbrock carbs (Carter AFB's) so this little guy is full of new gremlins to me.
GrimGreaser
To old to change, to young to quit.
