| | | Forums66 Topics128,030 Posts1,055,418 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2010 Posts: 59 Wrench Fetcher | | Wrench Fetcher Joined: Sep 2010 Posts: 59 | About a month ago i started my 216 up. Well i decided i would go ahead and put the radiator on and let it run for a while. So i put the radiator support and radiator on (just frame and motor at the moment). I Filled it full of water and noticed that i couldnt find my radiator cap.. So i went to town and and when i got back i noticed that the water pump is leaking from the bottom right by the mounting bolt. Is this a pump issue or gasket issue.. Im using my old pump but have the new gasket on. Do these trucks have a weep hole like the new ones do that leak water when the pump is bad? I looked at the pump while i was putting the motor back together and it seemed to be functional.. Anyone else had this problem?
Thanks!
Daniel
1953 Chevrolet 3800 Stepside
