the kickdown switch is tripped by the throttle, that's why it mounts on the carb, even if you don't take the engine, he won't need it without the trans wink the relay is the can on the trans case
be aware that the opening on the car bellhouse is slightly smaller than the truck one so the front bearing retainer on the trans is slightly smaller, take care on installing it
Bill [#2]
