0 members (),
54
3
Mod | | | Forums66 Topics128,072 Posts1,055,906 Members48,429 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2009 Posts: 269 'Bolter | | 'Bolter Joined: Feb 2009 Posts: 269 | Hello every one, I am looking for some information about the placement of the engine with in the frame rails.
1939 1/2 ton 1954 235 1955 bellhousing 19?? T5
I had cut out the front motor mounts but left the radiator support to fit a mustang II front suspension. A pair of side motor mounts were fabricated and are going to be welded on to the frame. I recently had my frame blasted and I am about to reassemble the suspension. The next thing to do is drop the engine in with the transmission so I can get the measurements to the rear differential.
What are the measurements for the placement of the engine; side to side - offset to the passenger side? Front to rear - not too forward because of the radiator and not too back because I do not want to cut into the fire wall. I plan to have the cab mocked up on the frame as a guide to ensure that I do not go too far back. How far up on the on the frame rail? What angle degree 3+ or 3-?
The rear suspension is a 4 link parallel. All installation of the suspension was done level; front to back side to side.
Thanks for the advice and help, Bread
