| | | Forums66 Topics128,151 Posts1,056,994 Members48,460 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Aug 2005 Posts: 6,378 Ex Hall Monitor | | Ex Hall Monitor Joined: Aug 2005 Posts: 6,378 | Leave the charger on it for a while then try it. Sounds like you have a parasitic load somewhere. FWIW there's nothing wrong with a properly maintained 6v system IMHO. Get a full charge on the battery, pull one of the cables and check for current flow between the cable you pulled and the battery with everything turned off. If you find current flow you get to play detective.
