1 members (1 invisible),
105
3
Mod | | | Forums66 Topics128,024 Posts1,055,395 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | Yes. I have a set on my '55 1/2 ton. Depending on what year truck they came from, you may need to do some minor grinding in the center bore to allow them to fit. Later versions have 6 "tabs" in the bore that were for centering the wheel on the hub. Those will interfere with the hub on the older truck as it is slightly larger. You only need to take the tabs down to match the bore diameter. Also, you may want to remove the rivits on the front drums. They were an issue with mine.
Bill Burmeister | | |
