| | | Forums66 Topics128,094 Posts1,056,066 Members48,433 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#82221 08/28/2007 11:06 PM | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | One wire goes to the cold light & 1 goes to the hot. The switch grounds the corresponding light. If the hot light stays on the wire must be shorted. The ignition switch turns the hot light on when in the start position. This is to test the light. There could be a problem with the ignition switch or it may be wired wrong. I like to start with a new switch whenever I get a vehicle with a light. Then you know if it gets hot it will work. You should be able to ground each wire & the corresponding light comes on. They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | |
