When I had it installed in the dash I just had everything held by the 4 nuts in the back. I didn’t bend the tab over. To install it I just held the pieces with some tape, started the 4 nuts then pulled the tape back. It was not fun but worked.
I had that cluster installed but was not able to get it working, so I removed it to troubleshoot.
It turns out because I had painted the inside of the gauge housing I lost my ground.
Once I removed the paint it tested fine.
Unfortunately I have yet to get that thing in the truck. Been using a temporary under dash gauge
