| | | Forums66 Topics128,072 Posts1,055,903 Members48,429 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Aug 2000 Posts: 346 Shop Shark | | Shop Shark Joined: Aug 2000 Posts: 346 | That certainly looks like a GMC front crossmember.
The GMC engine is just a bit longer than the Chevy and many GMC trucks have a similar modification done to retrofit Chevy engines.
Do you have Chevy or GMC front sheet metal on the truck?
The crossmembers can be changed (GMC for Chevy and vice versa) but the front sheet metal mounting changes when you do.
'38 Chevy 1-1/2 ton '49 Chevy 1/2 ton '54 Chevy 6400 2 ton '55.2 GMC 3/4 ton '56 GMC 1-ton
No Room Left in Shop
