| | | Forums66 Topics128,041 Posts1,055,483 Members48,424 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2006 Posts: 649 'Bolter | | 'Bolter Joined: Feb 2006 Posts: 649 | How does the door fit in the opening, do you have even gaps all the way around? If so maybe the door has been twisted? It may require you to "bend" the door. Block the door just above the latch and with leverage force the lower portion of the door inward. The upper door frame is fairly easy to bend, just push/pull on it. I'd only do this if you've ruled out hinges and the cab opening. Becareful and try to avoid doing any additional damage to the door itself! | | |
