7 members (Donf, Gdads51, 55shaker, TUTS 59, Forty9, Donsz, Gray_Ghost),
126
1
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,056 Posts1,055,799 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#81863 08/22/2007 8:52 PM | Joined: Feb 2004 Posts: 29,773 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,773 | The R-45's will work fine. The only difference is the current flow in the secondary wiring, and there's less of a tendency to burn distributor cap contacts, rotor tips, etc. with the resistor plugs. At one time, there was a problem with using a resistor-type plug along with GM resistor wire, called "TVRS" wire, but the advice changed in the mid-70's at the GM training centers, and we were told to use resistor wires and resistor plugs together. As long as the resistance of a plug wire does not exceed 1,000 ohms per inch, the resistor plugs will work as well as, or better than the original types. Jerry
