It's definitely 'coil in cap'. I'm kind of confused by the 'one wire' that I keep hearing about. Does that mean that it only needs one wire hooked up, although there are other wires, or is there a model that actually only has one wire? Where would I look for a part number on it? That engine bay is so big that I have to get in with the engine to get to the distributor, and I'd like to spend as little time in there as possible right now.
195? Chevy 3800 dump truck
1973 Chevy C30 cab and chassis
1987 Suburban 3/4 ton 6.2L Diesel
