| | | Forums66 Topics128,140 Posts1,056,771 Members48,454 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Aug 2009 Posts: 311 'Bolter | | 'Bolter Joined: Aug 2009 Posts: 311 | Thank you everyone for your input. I had no responses before I reassembled so I applied the ultra copper as stated and torqued the few bolts I could get to with my torque wrench at 20ft lb then hand tightened all of them to a uniform feel. She started right up and low and behold No intake or exhaust leaks!! Now that my governor is removed there is a decent increase in the overall throttle response as well! While I had the manifolds apart I took the time to make sure my heat riser spring was wound properly and working correctly. I have this site to thank for all of the advice and tips that I utilized to bring her back to this condition. Thanks again! | | |
