| | | Forums66 Topics128,051 Posts1,055,764 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2006 Posts: 649 'Bolter | | 'Bolter Joined: Feb 2006 Posts: 649 | Just how thick are the bumpers? How about cutting them down? I measured mine and come up with about 1/2" thick. When the hood is closed I have about 1/4" gap. I can't figure out what sheet metal your bending? If you have to slam the hood so hard it's hitting the bolts, then I'd go back to the hood alignment/adjustment! Note, a properly adjusted hood moves rearward and down when latching. | | |
