| | | Forums66 Topics128,042 Posts1,055,516 Members48,424 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2006 Posts: 247 'Bolter | | 'Bolter Joined: Nov 2006 Posts: 247 | I would be very careful buying an assortment of bolts in bulk unless you know what you are getting. Many of the cheap assortments are just a grade 2 bolt. I would nerver use less then a grade 5 bolt and prefferably a grade 8 bolt. Also make sure your nuts and washers match the grade of the bolt you are buying. Just for what it is worth. Jim
Entire Thread
Bolts, nuts washers
| Johnnywaz212 | 01/02/2012 1:27 AM |
Re: Bolts, nuts washers
| Achipmunk | 01/02/2012 1:49 AM |
| Whitedog | 01/02/2012 3:41 AM |
| DrewP | 01/02/2012 4:10 AM |
| J M | 01/02/2012 6:16 AM |
| Pete52 | 01/02/2012 1:34 PM |
| Scott's50 | 01/02/2012 1:57 PM |
| Lovethetruck | 01/02/2012 3:43 PM |
| DrewP | 01/02/2012 9:20 PM |
| J M | 01/03/2012 6:57 AM |
| Johnnywaz212 | 01/06/2012 10:48 PM |
| Super55 | 01/06/2012 11:04 PM |
| hippy | 01/06/2012 11:47 PM |
| Super55 | 01/07/2012 1:20 AM |
| Achipmunk | 01/07/2012 4:08 AM |
| tclederman | 01/07/2012 5:18 AM | |
