7 members (69 coupe, Gdads51, Phak1, jmoore, TUTS 59, 54farmtruck, 1955 1 Series),
91
2
Mod | | | Forums66 Topics128,188 Posts1,057,329 Members48,469 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#81233 08/14/2007 1:01 AM | Joined: Apr 2006 Posts: 159 Shop Shark | | Shop Shark Joined: Apr 2006 Posts: 159 | Radiowaves88, Something else to consider is the inlet and the outlet , they are both on the passenger side.You can always move the neck on your top tank as I'm going to do.I have a 6.0 Gen III and I'm using a 65 Burb radiator, and shroud along with the 2006 clutch fan .Beats the heck out of $400 for a new radiator.If it works great if not I'll try something else.Good luck
In the works 2006 GEN III 6.0 /4L80E/ 205 New process,A/C and power brakes .
