11 members (Eisenholtz, Gone, Peggy M, Donf, Otto Skorzeny, Wickedbass, Hawkman, NJC, GRNHydra, hdgeren, 1 invisible),
72
2
Mod | | | Forums66 Topics128,023 Posts1,055,370 Members48,420 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2006 Posts: 1,997 Big Bolt Forum Co-moderator | | Big Bolt Forum Co-moderator Joined: Sep 2006 Posts: 1,997 | I was hoping to find a transmission manual on line at the old chevy manual project site, but could only find 3 and 5 speed along with automatics. I am sure someone will chime in on the subject. But just wanted to relate a story about my 1952 Willys transmission. My brass syncro rings went out one time and I took the transmission out with the help of my manual. It wasn't hard to take it apart. Once I replaced the syncro rings and put the transmission back in and reinstalled it would pop out of gear. So I took it apart and the only thing I could find was there was a thrust washer on the back end of the cluster gear shaft that was a few thousands out. Got a new one and installed it, and that was the problem. I would try to rebuild first if the gears are in good shape. If the gears are bad I am sure it would be cheaper to find another one. Good luck. A day without laughter is a day wasted- Charlie Chaplin When wrestling a grizzly bear, you have to keep at it until the bear gets tired, not when you get tired. 1948 Chevy 2-Ton | | |
