| Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,949 | If you plan to remove the throttle plate, grind the peened-over end off the screws with a Dremel tool before trying to remove them or you'll ruin the throttle shaft and/or break the screw before it comes out. The screws are peened to keep them from dropping into the engine in case one gets loose. Jerry
