The 1950 GMCs I was considering are quite a bit rougher than I was hoping, upon closer inspection. The 5-window cab has a horribly pitted and rusty ROOF all the way to the bottom of the windows! The doghouse and doors are good (this is the one-ton), and this one has a title. The frame is useless, due to a lifetime of hauling manure and letting it settle on the frame rails. The 1/2-ton has a good door and hood, and a decent 3-window cab. Decent bedsides. Both have 228 engines and four-speeds.
So, with that, I continue to look around for the right project.
Pessimist - Sees glass as half-empty. Optimist - Sees glass as half-full. Gov't- Sees glass and takes it from you because you have a glass.
Political Correctness: A philosophical belief system bereft of common sense and logic, that supports and rewards ignorance and stupidity.
