| | | Forums66 Topics128,049 Posts1,055,699 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: May 2005 Posts: 8,878 . | | . Joined: May 2005 Posts: 8,878 | Couple quick things.. SS brake lines use the same fittings and flare angle as stock, usually 45°. SS is hard to flare and bend, I've done it and it does work with GOOD tools.
I now exclusively use and recommend copper nickel brake lines. So much EASIER to work with. Most any autoparts store can get it these days, for example try part number CNC-325 for twenty five feet of 3/16". Other sizes up to 3/8" available.
Grigg | | |
