2 members (Ponchogl, Hush),
67
3
Mod | | | Forums66 Topics128,024 Posts1,055,395 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2004 Posts: 29,747 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,747 | Worn bushings in the throttle body will let the plate stick in the bore slightly off-idle, or it's possible that the throttle plate isn't centered in the bore if the bushings aren't the problem. Remove the carb, loosen the screws holding the throttle plate to the shaft, and tap it to center it. Then retighten the screws. Don't try to remove them completely- - - -they're peened on the back side to keep a loose one from falling into the engine. Jerry
