| | | Forums66 Topics128,021 Posts1,055,354 Members48,420 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jul 2001 Posts: 3,887 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Jul 2001 Posts: 3,887 | yes you can use it for a V8 if it's sound .... the best way to clean it is take it to a rad shop and have them clean and evaluate it ... no you can't add trans cooling internally unless you expect your trans to be lubricated with water and your engine to be cooled with ATF  you'd need an aftermarket cooler that mounts to the front of the rad Bill | | |
