Reset everything to fact specs on carb when took it off this weekend. New intake/exhaust gaskets, new fuel/vac lines, fuel pump, and installed a fuel pressure guage (4psi steady) and still at same problem. Holley rec's that I exchange float and see what it does. They think that the float may be the issue.
http://s971.photobucket.com/albums/ae197/jon63c10
1963 c-10 shortbed stepside 427 BBC T16 HD 3 speed
1963 c-10 shortbed fleetside 348 "w" 1st gen big block & powerglide
