i am thinking about putting an electric fuel pump in line to fill the carb bowl after extended non-use. the idea would be to use as a primer with a momentary switch in the cab to pump fuel up for ~30 seconds before turning over the engine. i did this on my boat, but that has a main fuel pump that was electric. questions:
1) anything wrong with this idea?
2) anyone done it?
3) will fuel pumps pass fuel when not energized - better yet, anyone have a p/n that they know does this? once running, i want the mechanical pump to take over.
thanks for comments/ideas/feedback
