| | | Forums66 Topics128,211 Posts1,057,472 Members48,473 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2006 Posts: 9,671 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 9,671 | Okey Dokey, gonna write the last chapter of this novel..
I drained out the Mobil Delvac Synthetic Manual Transmission fluid 50 and refilled with Citgo, Mystik JT-7 85w-140 gear oil, which I've run in all of my rear ends and manual transmissions for many decades now, and guess what................ NO MO GRINDING THE GEARS!!!!!
Old Bluebelle shifts like a new transmission again. I’ve driven it a few hundred miles mostly around town since the switch just to prove out the difference and it shifts as smooth as silk syncros working just as they should
So from my personal experiance with a brand new SM420 rebuld, stay away from the synthetics in the gearbox and stick with the old tried and true multigrade gear oils.
Denny Graham Sandwich, IL
Denny G Sandwich, IL
