Originally posted by Joe H:
Pull a battery cable before inserting the tool, you don't want to change out a piston and rod due to a mishap!
Joe
That's why I tell folks to use a dowel, also its easy to mark on, as it goes up/down it can be used to find TDC using the marks. I've seen guys tear up pistons using a TDC stop
