| | | Forums66 Topics128,148 Posts1,056,811 Members48,454 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | Any IFS for the Task Force trucks will require fabrication and welding. Closest to a "bolt in" will be the '73-'87 Chevy full size truck, as the crossmember for suspension can be taken out of the donor truck in one peice. it would need narrowed to fit the TF chassis, plue you would need to fabricate steering box and idler arm mounts.
Bill Burmeister | | |
